O-Clamp Slipping
Have a Tip? Share IT!
matt
Admin
FreeStyler Version: NULL
Twitter: twitter.com/hankosky
O-Clamp Slipping
Post by matt »
If you use O Clamps Like These,
You may notice that they twist on the bar no matter how tight you get them.
A Trick is to wrap the pole with Gaffer tape first, then clamp over the tape. This will prevent the light from moving!
Matt Hankosky
flickr.com/photos/mattxhank
dmxlighting
FreeStyler Version: beta
Re: O-Clamp Slipping
Post by dmxlighting »
??? You must be using really crap clamps!
I use metal ones (doughty) with no slip problems.
Think I'd get pissed of if some covered my truss in gaffer tape.
Return to “Tips from the Pros!”
