Hello
I search the fixture for the laser contest razor TRI .
Thank you for your help
Oriambre
Need FIXTURE : Laser contest Razor TRI
- FreeStyler Version: 3.2.1
- remco_k
- FreeStyler Version: N/A
Re: Need FIXTURE : Laser contest Razor TRI
This is no request forum.
All available fixtures can be found in this forum if not, then it does not exist.
...Yet. Here is where you kick in.
First: Read the forum rules in red, at the top of your screen.
Second: Then get your manual, find out the DMX channel functions, and try to understand what they do.
Third: Start the Fixture creator and create the fixture yourself.
Fourth: Post it in the user created downloads subforum for other users to be found _and_ to get your fixture file released within the next release of FreeStyler.
If you fail to get it to work, post your exported fixture file here (*.pff) and tell use what you've tried, what fails and how it should work.
Ofcourse together with the DMX channel function description.
