Ok, so I've been trying to get this fixture to work right and it isn't. I have input all the correct channels and values. Is there anyone out there who has this unit on the Freestyler that works properly and could you send me that fixture file? please
Unit is Chauvet Intimidator 2.0 DMX 605A Scanner.
Here is the Manual I found http://www.chauvetlighting.com/products ... ug-145.pdf
Need a fixture file for a Chauvet 2.0 DMX 605A unit
Archtriton
- FreeStyler Version: 3.2.1
- Twitter: twitter.com/davrim
- remco_k
- FreeStyler Version: N/A
Re: Need a fixture file for a Chauvet 2.0 DMX 605A unit
Moved the topic to the proper subforum: FreeStyler Fixture Files - Help & Support
Archtriton; if you can't find the fixture file here, then nobody probably made it before (or did'nt upload it here, shame!). So asking that, would be useless.
Make another attempt on making you own fixture file, try to understand what you need to do. Take another (about the same) fixture for an example, its really easy.
If you can't get it to work, post your exported fixture file (*.pff) here in this topic together with a good description of what you did try, what fails and all other info you have.
poppy8ohmsx32
- FreeStyler Version: 3.5.5
I have the same fixture, I used the chauvet intimidator 2.0 new from the pre installed fixture list in the freestyler software, mine works perfect
