Lpr2dmx does not work on pcmcia parallel converter
davide_maggio
Post by davide_maggio »
Hi, I have acquired one converter pcmcia to parallel port for the portable PC, now I must connect to us the iterface "lpr2dmx" but with the software freestyler it does not work as this converter has like id ffe0 and not 0378 like a normal parallel port standards, as I make to resolve this problem? it would only be enough to change id of the port on the software freestyler
thank!
Reason: Edited your title "HELP ME PLEASE!!!!". It was'nt very informative and does not invite people to read your topic.
FreeStyler Version: N/A
Re: Lpt2dmx does not work on pcmcia parallel converter
Post by remco_k »
Why go through so much trouble with rare devices?
Why not just buy a new USB to DMX converter, without all the hodgepodge?
davide_maggio
but it would only be enough to change the address of the parallel on software track that I have acquired the converter :cry: :cry:
cyberb0b
Commited FS Forum helper
Post by cyberb0b »
Nope wont work.
Your missing some communication between the parallel port and the usb version (universal SERIAL bus) :p...
There is a diffrence between a onboard parallel port and an usb one.
There are lots of programs that do not work on a usb parallel converter.
Thats my experiance.
Its not a problem with freestyler but a problem with windows.
Post by remco_k »
davide_maggio wrote:but it would only be enough to change the address of the parallel on software track that I have acquired the converter :cry: :cry:
Does other software that can control this interface work then?
cyberb0b wrote:Nope wont work.
davide_maggio is not using an USB to Parallel converter but uses an pcmcia to parallel converter. Very big difference.
So somehow it might or should work, but it might be possible that FreeStyler hardcoded "prints" :mrgreen: to adress 378 when LPT1 is selected.
Maybe some trick is possible in windows, maybe FreeStyler can be adapted, maybe LPT2 or 3 works.
Thats why I started saying "Why go through so much trouble with rare devices?", as many things in this situation can block. Or might block someday in the future.
Return to “DMX Interfaces”
