Shape speedmaster
martijnadegeest
Shape speedmaster
It would be great if you can program a speedmaster for al the active shapes. So if al my scans are in a certain shape (like a cirkel) and suddenly are slow song comes up, I can slow down al my scans with the shape speedmaster.
- remco_k
- FreeStyler Version: N/A
Re: Shape speedmaster
Never thought about it that way. Don't know of a certain workaround exists to get the same result.
I think its a pretty good idea!
aquas
You can use the sequence speed controller on the left in the CUE window. Ok it's different, you need to move one by one, but is an option.
cumpr
cumpr
In the Cue Window you also have the master speed, you dont need to slow down every sequence one by one.aquas wrote:You can use the sequence speed controller on the left in the CUE window. Ok it's different, you need to move one by one, but is an option.
cumpr
