Freestyler & Winamp Topic is solved
dizzo007
Freestyler & Winamp
Does anybody know how to access winamp from the timecode selection. It seems not to be available in version 3.0 or 3.2. Very valuable plugin is a must have.
dizzo007
Re: Freestyler & Winamp
It would be great to get it back.. Since its not been available it has been a huge struggle to get cues right. They are way off now not having winamp trigger at the right time.
dizzo007
Any news for adding an MP3 or WAV syncronizer to Freestyler. It is very much needed.
- remco_k
- FreeStyler Version: N/A
I am thinking of creating a plugin for this in FreeStyler as I see this request quite often.
I have never ever used or seen working the Winamp->FreeStyler sync, so I pretty much had no idea what it should do.
I have contacted Raph about it and already have some information about how stuff should work.
Also Raph needs to make some changes in FreeStyler as plugins can't load sequences in the cue at the moment.
Still I want some feedback from users, can you (all) explain to me how it did work in the past and what did you miss back then?
I can't promise that I will make this plugin, depends on how much work it is and if Raph adapts FreeStyler for it.
- remco_k
Nobody responded yet.
This gives me the feeling that the problem is'nt so big as I believed it was.
It's better to go on in this topic: FreeStyler & Winamp timecode sync
There's a poll to find out if its worth creating.
