So I got sound to light running on startup by using a macro (thanks to LJ_krede.dk for the idea). The sound to light programs works great, however has caused some problems, I want to know what you think.
When playing cue's and using override, I find sometimes the override gets stuck on, even with the button releasing. The "release all" button gets the override to stop but next time I use override, when unclicking it the previous override gets stuck on again. Everything just seems completely buggy, I see that 50% of my processor is used by sound 2 light so maybe I'm not using a nice enough machine? Do you think an audiocard would help take the load off the processor or help the situation?
Without sound to light running everything runs fine. I have tried setting sound to light refresh to level 6 using least amount of processor. I have no other programs running at all other than sound to light and freestyler and not even connected to the internet or using antivirus. Thanks for your thoughts.
Sound to Light messing up overrides.
djsno
- FreeStyler Version: 3.4.4
Intel Core i7-3820, Corsair Vengence 32GB (8x4GB) DDR3 1866MHz, EVGA GTX-560Ti
Windows 8 Pro
Enttec DMX USB Pro (pre-built) FS 3.44
Windows 8 Pro
