Eurolite LED bar 324/10
Post by LJ_krede.dk »
EUROLITE LED bar 324/10 RGB
YouTube Video
Features
  • DMX-512 control possible via any commercial DMX-controller
  • 5, 8, 11, 20 DMX channels selectable for various applications (1, 2, 3 and 6 LED segments)
  • Sound-control via built-in microphone, activation and sound sensibility can be controlled from DMX
  • Functions: static colors; automatic color change, 14 built-in programs and strobe effect with variable speed; Master/Slave
  • On-board control board with 2 x 8 character LC-display
  • Locking possibility at the mounting bracket
  • Ready for connection with power cord and safety plug
  • Advantages of high-power LED-technology: extreme light output, extremely long life, low power consumption, defacto maintenance free
Specifications
  • Power supply: 230 V AC, 50 Hz ~
  • Power consumption: max. 85 W
  • DMX-control-channels: max. 20
  • DMX-512-connection: 3-pin XLR
  • Number of LEDs: 324
  • Beam angle: 30°
  • Dimensions (LxWxH): 800 x 135 x 100 mm
  • Weight: 4.5 kg
Fixtures
the uploaded fixtures is for 20 channel Mode (6 segment)
you can control the LED bar on two ways:
  • eurolite LED bar 324-10 - 20ch.pff
    (66.12 KiB) Downloaded 156 times
    One fixture. The RGB fader in Freestyler controls the first LED segment.
  • Eurolite LED bar 324-10 - 20ch.rar
    6 fixtures: RGB channels on each fixture controls different segments of the LED bar.
    Make sure all six fixture have same address!!!
    eurolite LED bar 324-10 - 20ch_1.pff: The RGB channels controls the first segment
    eurolite LED bar 324-10 - 20ch_2.pff: The RGB channels controls the second segment
    eurolite LED bar 324-10 - 20ch_3.pff: The RGB channels controls the third segment
    eurolite LED bar 324-10 - 20ch_4.pff: The RGB channels controls the fourth segment
    eurolite LED bar 324-10 - 20ch_5.pff: The RGB channels controls the fifth segment
    eurolite LED bar 324-10 - 20ch_6.pff: The RGB channels controls the sixth segment
    (50.26 KiB) Downloaded 168 times
    If you want RGB faders for each segment download this file. contains 6 fixtures used for one LED bar.
    I am using this to control the LED by MIDI interface, so I select a fixture which controls the desirable segment and using the RGB faders on my MIDI interface. you can control all segments in all fixtures, its just the RGB channels which is different. Intensity and Strobe is the same for all segments
If you want to use the LED bar in other modes, with 1, 2, or 3 segments and still use the rgb channels for each segment, you can still use these fixtures below. the Be aware the fixtures still use 20 channels in Freestyler so dont path any other fixtures to these adresses:
  • 1 segment: use eurolite LED bar 324-10 - 20ch_1.pff
  • 2 segments: use eurolite LED bar 324-10 - 20ch_1.pff and eurolite LED bar 324-10 - 20ch_2.pff
  • 3 segments: use eurolite LED bar 324-10 - 20ch_1.pff, eurolite LED bar 324-10 - 20ch_2.pff and eurolite LED bar 324-10 - 20ch_3.pff
EDIT: If you dont want to download the .rar file all the pff files is uploaded in a later reply in this topic.
I made the rar file beacausee the forum only allows max 5 files per message.
FreeStyler Version: N/A
Re: Eurolite LED bar 324/10
Post by remco_k »
Someone has spent some time. :mrgreen:
Good work!
Still I have someting nag about.
We want all fixture files to be in .pff format.
I think I know why you uploaded in .rar, but can you please upload all the .pff files seperately?
Thx
remco_k wrote: I think I know why you uploaded in .rar, but can you please upload all the .pff files seperately?
Thx
i did it because the forum only allow 5 uploaded files per message, and I have 6 fixture files.
here is the first five fixtures:
(66.12 KiB) Downloaded 158 times
(66.2 KiB) Downloaded 148 times
(66.2 KiB) Downloaded 154 times
(66.27 KiB) Downloaded 156 times
(66.27 KiB) Downloaded 152 times
Here is the last one:
(66.27 KiB) Downloaded 160 times
tech
Post by tech »
many thanx
Return to “Eurolite”
