Martin SCX 600 Scanners Topic is solved
djdougatl
Post by djdougatl »
I am needing help with my new martin scx 600 scanners. I see in the fixture file that was created, there is so many features of the fixture, but how do you get the sound to light to work with say the strobe effect or the music trig features for the fixture. I know how to program gobo, color, pan, and tilt, but kinda confused on why all the other music trig values but they won't work.
I look forward to respones.
DJ Doug
dmxlighting
FreeStyler Version: beta
Re: Martin SCX 600 Scanners
Post by dmxlighting »
djdougatl wrote:I am needing help with my new martin scx 600 scanners. I see in the fixture file that was created, there is so many features of the fixture, but how do you get the sound to light to work with say the strobe effect or the music trig features for the fixture. I know how to program gobo, color, pan, and tilt, but kinda confused on why all the other music trig values but they won't work.
Im not quite sure what you mean.
There is no option for shutter or strobe effect on the sound to light window. Its pan, tilt, gobo, colour and thats it.
The only way would be to create a sequence for the shutters and play it back in the cue window with sound activate trigger on.
Hope this helped ?
djdougatl
Post by djdougatl »
Ok so creating a macro for the music trig strobe will allow the fixture to use it's internal mic to strobe to the beat of the music. Cool I think that answered it for me. On the fixture file, there are so many features that allow music trig so I will create a macro for them.
Thanks,
DJ Doug
djdougatl
Post by djdougatl »
So when you use those on the fixture then it sets it to music. Cool Thanks,
