Showtec MiniMax 250
DrReaper
Showtec MiniMax 250
Post by DrReaper »
Here is my created Fixture for the Showtec MiniMax 250 ELC
Best regards,
Reaper
This 7 channel DMX Fixture provides a basic arsenal of effects to get any party started. Not only with colour wheel but also with gobo wheel in a compact housing. The unit is suitable for most of the small and medium productions.
Lamp: ELC 24V / 250W
Lumen output: 1500 Lux
Luminious flux: 1200 Lumen
Digital addressing
Colour Wheel: 8 vivid dichroic colours
+ open + rainbow effect
Gobo Wheel: 7 selectable gobo's
Manual Focus
High speed shutter (1-10 flashes per second)
510 degrees Pan movement
260 degrees Tilt movement
Multicoated quartz lens
8 and 16 bit resolution (selectable)
7 DMX Channels
Auto-mode, Music-mode, DMX-mode
Dimensions (LxWxH): 220 x 220 x 480 mm
Weight: 5,25 kg
MiniMax 250.pff
The Fixturefile
(75.47 KiB) Downloaded 143 times
Return to “Showtec”
