Back after a long time:D I just needed to use Freestyler for a small gig at school, and there will probably be some dumbasses using the software, so I thought I'd put the software in touchscreen mode, as it is bit easier to access with the big buttons... But then you can only select slow-med-fast strobe. (which of course you normally can too, but then I usually just use the faders on the right) So I'll go with the normal view (as it has some other advantages too)
But what I thought, isn't it possible to make the strobe control a bar with percentages or something (like in Lightjockey)? Not only for touchscreen control but also in the standard screen. IT would just give you slightly more control, and I guess it won't be too hard to implement, as it is basically the same as intensity, only assigned to another channel...
Dunno if anybody has already requested this, but I don't have time to search, so if anyone has already, I'm sorry
Jayke
PS, I know notice I've placed it in the wrong forum, it should be in the ideas and remarks... sorry!:P
