Hey guys, I'm new to Freestyler.
I just wanted to know if there's any way to put a timeline in Freestyler to allow it to sync lights with music.
Thanks!
iMicrochip
Timeline
aquas
Re: Timeline
there is in the Cue window a column where you can use the real time or "time count". this is in the end column, where you set the time that you want start the sequence. but i think you need to activate the time module in the setup... Check in the forum about the Sound to llight, and time line, because is allredy discusted in the forum.
I think that some where as the information about this, check to the help file in FreeStyler.
cumpr
cumpr
