FreeStyler ROCKS! Reverse Scene Keyboard Shortcut? Topic is solved
dayoung24
Post by dayoung24 »
I recently used FreeStyler to run lights for my brother's rock band show (2 4 channel dimmer packs controlling 14 Par cans w/ various colored gels), and it worked flawlessly!!! I used a mixture of static and chase scenes far more fun than their old DMX control board! :D
While I learned a lot and made a lot of scene and cue list tweaks after this first show, I still can't figure out how to map a shortcut key to reverse a scene. Can anyone help or is this not possible?
I would also like to echo the request I have seen in other posts to allow more than 20 scenes in a cue list as toggling cue lists in the middle of a rock show is not the easiest thing to do.
Thank you!
