Change button over time
scottbramall
FreeStyler Version: lates
Post by scottbramall »
What would be great is to have an option of fading between buttons over a ediatble time. So in live mode you could type in a time such as 5, and then press the button you want to move to.
Then the button would fade over 5 seconds to the button.
This would be great for me as i use the buttons for positions
Regards
Scott
FreeStyler Version: N/A
Re: Change button over time
Post by remco_k »
2 options:
1. I completely misunderstand your question (I need some sleep... But get stuck in messaging fever on few forums)
-or-
2. Make a sequence and run it in the que window? There you can set speed or manual trigger times.
Return to “Ideas and Remarks”
