Limit pan & tilt movement
Scartio
FreeStyler Version: 3.0
Post by Scartio »
Hey,
I'm busy working on a new fixture file for a Laserworld RGY laser. Since it's only my second fixture file I'm still in a "newbie" mode....and yes - ILDA softare would be nicer.....but I'm missing the $$$....
The X and Y controls are controlled by two different DMX channels. Nothing special you would say....but the the channels are " split" this means that a value of 0-127 controls the movement and values above 127 forces the laser into a auto movement feature where 128 tot 255 controls the speed by the auto movement feature. For now I implemented some macro's for this last function but as you would think I would like to control the movement with the standard pan/tilt window with values between 0-127. How can I achieve this ?
Thanx for any help !
kikabyte
FreeStyler Version: 3.00
I Use FreeStyler for: Church
Re: Limit pan & tilt movement
Post by kikabyte »
That sounds like a difficult fixture to work with.
In one of upcoming releases, you are given the opertunity to to the min, and max of a channel output. This wouldnt work very well in your instance, but it would be a rough solution.
