Hi
I'm trying to trigger some events in FreeStyler X2 from an OpenRemote home automation configuration.
With the help of your tool I've solved the initial correction problems I was having, but I've hit a brick wall when it comes to formatting the commands in OpenRemote.
As you can see from the screen grabs here, I've got quite a few options.
I've tried using all 3 of the http styles,
Post
Get
Put
But nothing happens in FreeStyler, other than the remote control icon appearing.
(Which I clear between tests)
So I'm assuming I have to use a user name & password?
Or do I have to structure the TCP commands in a very particular way?
Really all I want to do is toggle some chases / sequences.
Any help you can give would be very welcomed.
FYI,
I've got a TCP controlled Relay board that uses the following commands, that works very well
