Flickering in color mixing mode with Chauvet Colorstrip Topic is solved
matt
Admin
FreeStyler Version: NULL
Twitter: twitter.com/hankosky
Re: Flickering in color mixing mode with Chauvet Colorstrip
Post by matt »
well i can also tell you that the flickering is worse with the Velleman then the Enttec Open Interface
Matt Hankosky
flickr.com/photos/mattxhank
matt
Admin
Post by matt »
I will post video.. but with 3 of these units in link mode.. its pretty sweet.
Matt Hankosky
djharryg
Commited FS Forum helper
FreeStyler Version: 3635
Post by djharryg »
What does it mean to change the "channel address" to 5? How do I do that?
Freestyler: V3.6.35
dmxlighting
FreeStyler Version: beta
Post by dmxlighting »
djharryg wrote:What does it mean to change the "channel address" to 5? How do I do that?
Do you mean changing the dmx address to 5?
Each colorstrip is 4 channels of dmx so if your first fixture is on channel 1 then the next fixture should be addressed as channel 5. If that fixture uses 4 channels then the next avalible channel will be 9 and so on.
To change the channel address you should refer to the user guide.
I will point out that you can have identical fixtures on the same channels and then will then both read the dmx signal a react at the same time.
You cannot ever overlap channels as this will cause strange thing to happen (it won't damage anything though).
djharryg
Post by djharryg »
I think I'm going to order the Enttec Open DMX for Sirs-electronics. It's about $56.00 there. The only thing is that Enttec is a 5-pin connection and all my cables are 3-pin. Will the performance of the Enttec be bad if I use a 5-pin to 3-pin adapter?
Freestyler: V3.6.35
Post by LJ_krede.dk »
djharryg wrote:I think I'm going to order the Enttec Open DMX for Sirs-electronics. It's about $56.00 there. The only thing is that Enttec is a 5-pin connection and all my cables are 3-pin. Will the performance of the Enttec be bad if I use a 5-pin to 3-pin adapter?
No. there is no signal in the two extra pins.
whines
Post by whines »
Followup: I have replaced my OpenDMX with a ProDMX, and once I used the Pro utility to change the refresh rate to 20khz (is that the unit? I forget...anyways, from the default 40 to 20) the problem with the Colorstrips (and similar problems with other fixtures) went away.
So in summary, if you use the OpenDMX, avoid color mixing. Opting for the ProDMX will give you full functionality once you tweak the output rate.
