Help: Strobo channel goes 255 when sequence is loaded Topic is solved
Hambone
Band Member
I Use FreeStyler for: Band
Re: Freestyler is really buggy
Post by Hambone »
This might be related to bug #1648 - certain channels on certain fixtures get stored with the wrong values when saving a sequence. It's such a regression that I've been unable to use 4.1.1 at all and was forced to roll back to 3.6.51 (the last version I had available).
http://two-for-flinching.com
Hambone wrote: 20 Jul 2022, 18:31 This might be related to bug #1648 - certain channels on certain fixtures get stored with the wrong values when saving a sequence. It's such a regression that I've been unable to use 4.1.1 at all and was forced to roll back to 3.6.51 (the last version I had available).
Hambone, all the previous versions fyi are available like 4.1.0 underneath the FS download link...
Plus there doesnt seem to be a major complaint about this issue from others...
GiovanniG
Post by GiovanniG »
Thanks for checking, in the weekend I hope to have less work and more time for this (
I'll try to reinstall it and use backup. Yes I can move it to zero an have zero strobe in fixtures too, I save it, I losd it back and the strobo forse again to high.
GiovanniG
Post by GiovanniG »
Hi, I've deleted and reinstalled, imported backup, nothng changed. SOme sequences driving the strobo to 211 or 255, some don't. Difficult to say for me wher eis the problem.
Have you tried import backup as well? have ou notied on DMX output what I've just written?
If you imported the old file you might need to edit the sequence and re-save to fix the problem in otherwise you've just imported the problem back
GiovanniG
Post by GiovanniG »
Hi, I did, I loaded the sequence, reset the strobo values and ovewrote the sequence, loaded it back, the strobo still.
SOme sequences may save the strobe to zero, some others can't, and there is "snap" selected (to zero). I suppose there is a probelm with Freestyler.
If I try the version3, can I import there the backup too? Is compatible?
You never replied me, have you noticed the same problems with you installation?
GiovanniG
Post by GiovanniG »
I wanted to roll back to 3.6.51 but with this version I can't see any fixture bakc, probably they are not compatible.
I'm won't rebuild everything, so I really hope this bug can be solved, or there is a backup-compatible 4.x version that may work.. thank you
GiovanniG
Post by GiovanniG »
Hi mate, have you fixed it in 4.1.2?
If you are interested on a Anydesk connecto to that PC, you can figure yourself the problem.
The problema appears each time I load a sequence, but not with all sequences, jus some with more than one scene.
I hope you can fix it soon, thanks
GiovanniG
Post by GiovanniG »
Hi, I've downloaded the latest version but the bug still not fixed.
Do I have any chance to have Freestyler work in future? :(
Re: Help: Strobo channel goes 255 when sequence is loaded
Have you added it to the bug tracker?
GiovanniG
Post by GiovanniG »
Hi, thanks for answer, yes I did, here it is:
https://www.freestylersupport.com/bugs/view.php?id=1662
I've just noticed that dj-Ralph offered a fix to test, sorry I haven't noticed it (I aven't received a warning email), so I hope he can keep help me
GiovanniG
Post by GiovanniG »
I've downloaded the 4.1.3 (before posting here I've donwloaded it, but for an unknown reason it downloaed again the 4.1.1 and I've tested it, instead of 4.1.3) and the problem is fixed, I?m glad of it, thank you!
Ok don't forget to update that it's fixed on the bug tracker please
GiovanniG
Post by GiovanniG »
I've closed the issue there too :)
Sweet cheers
Return to “Ideas and Remarks”
