GO Monkey - Theater / Band Cue Stack
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: GO Monkey - Theater Cue Stack
CutDMX12
- FreeStyler Version: 3.5.2
Nice job!Mattotone wrote:any takers???
now now more sitting at the back with my fingers cold typeing the XML code out as thay act....
nice job....
i think get the XML gen to load and edit the XML then i think Go Monkey could be included with FreeStyler when someone downloads and installs it
Nice work
C12,
- Mattotone
http://www.freestylersupport.com/fsforu ... hp?id=1362 this version allows just that. Editor will be included with next monkey release. Being included with fs is up to raph but would be welcomed
- Mattotone
latest version of Fs has fixed the reverse issue.
I used goMonkey for the first time in a real enviroment, small issue found with the xml creator.
the creator adds. .chb to the end of the sequence name in xml. this is not required and will create a file not found error.
trapgunner
Hello, I tried to use FS and GO monkey, but no sucess.
First of all I want to know if I can do what I want if this app.
I have a music and I want with just one start command the program change the sequences sync with the music, this is possible? I want something like that:
I press the start button toghter with the music
0.0 seconds - sequence1
1.2 seconds - sequence 2
2.5 seconds - sequence 3
- Mattotone
Unfortunately not the current resolution of the timer is 1 second, apart from that it would be able to do this.
Look out for the show Monkey. This will do what you want but is along way from being finished.
trapgunner
have some another free software I can use for it maybe with a timeline?
htaxil
It seems that all the .chb files must be in the "C:\FreeStyler\Chases" folder, otherwise we get an error "File not found". Sequence classification by sub-folders should be avoided.
File names must not contain accented characters otherwise we get an error "Bad file name or number".
After saving XML file with "GoMonkey Easy XML" we must edit the xml file to delete the ".chb" after each sequence name otherwise we get an error "File not found".
It appears that the "Fade and Loop" options are in reverse logic : when one of these options is checked in GoMonkey, the option is disabled in freestyler.
Unfortunately, there are often errors when trying to save the XML file. In most cases, an error window appears, but not always. There, I have not had but the file was empty. Here's what's left of my work
Another problem : I created a list of five scenes. Each scene contains séquences, not always the same number. On some scenes, sequences do not start to play. I see them loaded in the cue but I have to click on "play" button for them to play.
This happens to me on scenes with the same number of sequences. In the example below, only the sequence three starts automatically :
1 - ok, the first two sequences are played only once (but the second was not played)
2 - the first sequence does not change anything , I don't know if it works. The second will not start.
Strange, when I change the order of sequences, it changes the behavior of my scene. Here, I switched the last two sequences and it started automatically every two.
I try a new order ... No, it works less well.
3 - the first and second sequence does not start automatically.
the order of the sequence changes the behavior of the scene.
another order... no
But for this last step, it seems that there is a timing issue. The sequence "Fade-1par1-Gad," which does not start, is in the final sequence of the last scene of my list ...
And it starts on the following set that includes only one scene
following set that includes only one scene that normally does not use this sequence...
Another problem ? ok, I am in shape this evening
In the example below, the three sequence run automatically (I do not know why it works here). The problem here, the first sequence drive a dimmer but nothing happens physically. To make this work requires me to intervene on the cue to stop and start this sequence...
I hope I'm clear ...
Any ideas?
regards,
Hubert
another order... no
Any ideas?
regards,
Hubert
- Mattotone
version 6 released
Edit/create the cue stack in program.
create loops in the cue stack.
various bug fixes, fixed issues with random/fade/loop being reversed.
removed the error of adding.chb to end of file names in the xml
error checking added to xml reader.
Known issues:
no folder support all sequences must be in single folder (This is how FS accepts Sequences)
not looping a sequences causes sync issues with sequences play/pause leaving go monkey to not be able to restart sequences. This is down to FS being unable to report its play/pause status.
Known issues:
- Mattotone
version 7
Update to address the problem where a scene would not play under certain conditions.
The software no longer needs to keep track of the play/stop status of sequences within the freestyler software.
- Mattotone
Has any one managed to play with this, There were quite a few changes that do require testing fully.
Pidea
- I Use FreeStyler for: Band
Hi there ! I play drums in a band and want to be able to control the lights via MIDI signals sent from a Roland trigger pad. At the moment I've programmed FS with a light show for a particular song. I've done this by creating a sequence for:
* the intro (45 seconds)
* a verse (60 seconds)
* a chorus (20 seconds)
* the solo (25 seconds)
* the outro (30 seconds)
and I've set up a cue stack called song 1 and dragged each of the items into it in the required order:
* intro
* verse
* chorus
* verse
* chorus
* solo
* chorus
* outro
I'm hoping to be able to step through each one in turn so at the start of the song I trigger the intro which runs for 45 seconds and then it holds until I manually trigger the next sequence for the verse and so on and so on.
Is this possible ? If so, what combination of parameters do I need to set because I've tried pretty much everything and can't get it to work.
If I understand this right, the wait time is the total time of the song (in this example 280 seconds) and if I tick 'Halt' then at the end of the song then it won't go to the next cue in the list (song 2). Is that right ?
Also, would it be possible to list the cues in the left hand column of the main window and the sequences for that cue in the right hand column ? That would make it much easier to see which sequence is running at the time.
Thanks in advance !
* intro
* verse
* chorus
* verse
* chorus
* solo
* chorus
* outro
Thanks in advance !
- Mattotone
The wait time is the amount of time the software waits until GOing onto the next cue. so for your into this could be 45 seconds and then it will advance onto the next cue, if you want it to wait untill you next trigger then select the halt option, it will keep the cue running until you press GO, which will then load and play the next cue.
Freestyler will list the running sequences in the normal cue window if you need this information.
Pidea
Thanks for the reply Matt.
Based on what I read that's what I thought would happen but having set it up like that it doesn't run as expected. I've just got back from band practice so my brain addled - I'll take another look in the morning and will post my findings.
- Mattotone
Try version six. Version 7 doesn't seem to work correctly with Fs and needs looking into.
Pidea
Thanks for the tip Matt, just tried to download version 6 from the first post of the thread but WinRAR is reporting that the header is corrupt. I'm getting this error on two different computers.
If you've got a moment could you re-upload it ?
- Mattotone
Must be part of the forum moves. I will post v6 back up tonight.
Pidea
Thanks for that Matt, interestingly some of the other forum attachments are fine. Wierd !
- Mattotone
Re-uploaded version 6.
- Mattotone
Version 8 released
kittmaster
- Commited FS Forum helper
- FreeStyler Version: 3.6.2
Just downloaded it with my example rar you gave me, but since I changed the names, it seems like I've fouled it up......will try it tonight when I get home.....looks promising.
kittmaster
added two chases....hit add to stack....died
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.FormatException: Input string was not in a correct format.
at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info)
at FS_Go_Monkey.xmlGui.addToListButton_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5466 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
FS Go Monkey
Assembly Version: 3.2.0.0
Win32 Version: 3.2.0.0
CodeBase: file:///C:/Users/Chris%20Bertrand/Desktop/example/FS%20Go%20Monkey.exe
System
Win32 Version: 2.0.50727.5467 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
Win32 Version: 2.0.50727.5468 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Data
Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
CodeBase: file:///C:/Windows/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
mscorlib
FS Go Monkey
System
System.Drawing
System.Data
System.Xml
enabled.
For example:
<configuration>
</configuration>
kittmaster
Took the same scene 4 par forward red chase, added it twenty times, reversed every other with no sound..
Also, cue only has 16 entries, not 20 sent into the cue......some type of array boundary error:
System.IndexOutOfRangeException: Index was outside the bounds of the array.
at FS_Go_Monkey.Form1.RunSequence()
at FS_Go_Monkey.Form1.Go_Click(Object sender, EventArgs e)
mscorlib
FS Go Monkey
System
System.Drawing
System.Data
System.Xml
enabled.
For example:
<configuration>
</configuration>
mscorlib
FS Go Monkey
System
System.Drawing
System.Data
System.Xml
enabled.
For example:
<configuration>
</configuration>
kittmaster
Ok I did a logic check, I did a 4 par red chase pattern. I loaded the same chase by draggin it in this many times and its results:
5 times > ok
6 times > ok
10 times > ok
15 times > ok
16 times > crashes
So clearly there is a problem when more than 15 cue scenes created. While they LOAD into you program, the crash only shows itself when you press GO.
Also, the reverse is not working, I took the red chases, alternated as forward and reverse, only the forwards were working in the cue......seems reverse is somehow broken.
5 times > ok
6 times > ok
10 times > ok
15 times > ok
16 times > crashes
- Mattotone
version 8.1 bug fix released
