Freestyler not communicating with Magic 3d Easy View Topic is solved
Rosspunk
Re: Freestyler not communicating with Magic 3d Easy View
Post by Rosspunk »
Tried everything, now getting the hump. :(
buttza
FreeStyler Version: 3.6.4
Twitter: twitter.com/@buttza
Post by buttza »
Are you on XP?
You could try the windows 8 Fix that I am working on. I will try add it tonight. Using the Microsoft Loopback Network Adapter. (It is a Virtual Adapter)
buttza
Loopback Setup!
Post by buttza »
Hi I need someone to try this tutorial to see if it works for you. Thanks.
Loopback_setup.pdf
(462.39 KiB) Downloaded 345 times
Rosspunk
Post by Rosspunk »
Buttza, Yes I am still on XP.
buttza
Post by buttza »
Hey Rosspunk you could try the instructions I created below. It should work for XP.
viewtopic.php?f=56&t=6406
Polsound
Post by Polsound »
hey there guys
i seem to have an issue with my win7 and running easyview. all problems came up after upgrading from XP. yes, ive tried the win 7 fix, downloaded and installed everything as it should be but the FS doesnt seem to communicate with 3D. its says that it is controlled by FS and the DMX is on in ECO mode. still nothing.
also, im not sure if its win7 or videocard or setting problem but on the stage the screen doesnt load up the video normally only on the right upper corner of the screen and not on full screen mode. what the hell is this?
pls pls pls help!
this whole thing is going on my nerves.
any suggestions?
many many many thanks for the answers
Nathanrs93
FreeStyler Version: None
Post by Nathanrs93 »
Have you tired doing it the way Buttza in the post above??
danielvee
Post by danielvee »
I am having a similar problem , I'm on windows 7 , dmx is on virtual , load it from fs patch basic par cans , line up patches , dmx light is red in right corner , ??? ,really need some help on this one , totally doing my head in , I also have another laptop I tried to run this on , on the second laptop , MeV won't even launch from fs ,
Sent from my iPhone using Tapatalk
buttza
Post by buttza »
danielvee
Post by danielvee »
The universe options on mev start up screen are grey and can't b altered , dmx light in right corner is red ?????
danielvee
Post by danielvee »
I have followed all instructions
danielvee
Post by danielvee »
danielvee
Post by danielvee »
Heeeellllllppppppppp
danielvee
Post by danielvee »
Can somebody post the windows 7 fix
buttza
Post by buttza »
See image
Post by Jan_K »
Hej buttza.
Can you please place this info in the freestyler wiki.
I think this is relevant info for the "Troubleshooting" or "3D" part.
buttza
Post by buttza »
Will do Jan.
I will also add the loopback info etc too.
gammagoblin
Post by gammagoblin »
Hi
I am trying get easyview working aswell.
I am on Win 7. The DMX Lamp is green and it says controlled by freestyler.
But there is no change on the DMX channels when i change something in Freestyler.
The Lamps do not react, even though they are on the same channels.
I tried it with the virtual interface aswell as with the method butzza has shown for xp.
Does someone know that problem? Does Easyview only react on cues? does easyview need to go in a specific mode to show Freestyler actions?
edit.: now the DMX Level is shown, but the lamp does not shine. Fixture is a cameo Studio Par 64
Nathanrs93
gammagoblin wrote:Hi
Make sure you're not running an old version of 3D view!
gammagoblin
Freestyler is 3.6.2
Easy view is 12.12.2014. Its as new as possible (nicolaudie download site)
spud1511
FreeStyler Version: 3.5.7
Post by spud1511 »
If the dmx level is showing, then the communication should be there?
Did you remember to put the master intensity up by selecting the fixture, opening the lamp window, and increasing sliding the master up in freestyler? (I'm not joking or being silly - I used to forget this all the time when I was learning the ropes). Otherwise sending 100% of any colour is useless if the main intensity/dimmer for that fixture is zero.
gammagoblin
It certainly has something to do with the dimmer, because, the Par 56 (who dont have one) do react but the par 64 (who have one) don't. I Checked the lamp-dimmer, the master-dimmer. Everything shoul work. When i hit a cue one of the 4 Par64 is reacting even though it wasnt part of the sequence.
If i connect the lamps to th eInterface, they shine as they should.
spud1511
Post by spud1511 »
Then that points to a bad fixture within the 3d easyview program. It does have its own editor (nothing to do with freestyler one) where you can check the channel allocation and values are correct.
Unfortunately it is laid out a little differently and adds more things to figure out/learn into the mix, but you will probably find your answer in there.
gammagoblin
I checked the fixture in the scan lib. Didn't find the fault.
Thats the Freestyler fixture:
http://workupload.com/file/tXaw6Wg6
Thats the Easy view Fixture:
http://workupload.com/file/89ZNnQCq
gammagoblin
Does really nobody know why the Easyview fixture is not reacting to the FS comands?
