Hello,
I really do love Freestyler and I've been using it for quite some time now. Mostly for parties and band performances.
I like the GUI a lot but there's something that's been bugging me for some time. I'd like to use Freestyler for Theatre performances as well. Sadly, FS does not have band stacks.
And the UI of BandStack doesn't really do it for me.
I've noticed that I can use Submasters as theatre stacks. Just playing one sequence after another. Sadly, Submasters can only hold 20 sequences. Is it possible to make the submasters hold unlimited sequences?
Also, if I use Submasters I have to press the 'Go'-key and the 'Run'-key after eachother to make the next sequence play. Is it possible to Merge them in one button for Theatre stack purposes. Something like: "Play"?
Thanks in advance,
Bavo Ceulemans
Extended Submasters
Re: Extended Submasters
I agree, I'd like to have the same "play" function! It would be useful also for club/concerts lighting, for example to have one button cycling a cue list color assigned to a submaster!
- FreeStyler Version: 4.01
- FreeStyler Version: None
Remember to submit this on bug tracker as a feature request, then it might get under taken if it's something you really want.
- FreeStyler Developer
- FreeStyler Version: 3.2.1
Hi
I'm currently increasing the number of sequences a submaster can hold.
Let me know if you want to give it a test: freestylersupport"at"telenet.be
I'll look into the "Play" button request too.
Thank you
Raphael
Thank you
Raphael
Raphaël
