Showtec lightfoot 4 no go ???
blue slate mike
I Use FreeStyler for: Church
Post by blue slate mike »
I have a showtec lightfoot4 DMX and It doesn't willn't to work with a starville led cans. Will this unit only work showtec cans?? The lights work with my controller and a enttec Open DMX USB Interface ?
mike d
ug999
Re: Showtec lightfoot 4 no go ???
Post by ug999 »
hi,
late answer, but perhaps it helps somebody.
it'll work, but with a lot of restrictions:
as the controller is made to control a max. of 4 par cans (single color), all programs and chases will not work!
You can only use the scene mode.
Set the cans to channel 1 (so the controlled channels will be 1-4) (dip1 on, rest off).
ch. 2-4 will control the colors (0-255)
ch. 1 must be set to 0 in order to have rgb control for ch. 2-4
Now you can programm any colored scene and blackout as you like.
bloodandtears
Post by bloodandtears »
Sorry for the necro post, but I have the same setup as the OP but I cannot make this work at all.. please help..
Return to “Showtec”
