Colors not shutting off
tntproductions
I have a bunch of Lumi Professional 500 PAR 64 LED lights. I created several cues for the individual colors of red, green and blue. What I'm experiencing is when I turn on the red queue and switch to green, the red remains on. Then when I switch to blue, the red and green also remain on. Shouldn't they shut off automatically when I switch to a different color?
- FreeStyler Version: 4.01
Re: Colors not shutting off
Only if you program it that way. Many people layer cues for desired effects.
If you want something in a cue then add it but also anything you dont want in a cue needs to be set.
Your programming should look like this if you want the colors to not layer:
Red Cue
Red 255 Snap(yellow)
Green 000 Snap
Blue 000 Snap
Dimmer 255 Snap (if you have a dimmer channel)
Green Cue
Red 000 Snap(yellow)
Green 255 Snap
Blue 000 Snap
Blue Cue
Green 000 Snap
Blue 255 Snap
Red Cue
Green 000 Snap
Blue 000 Snap
Green Cue
Green 255 Snap
Blue 000 Snap
Blue Cue
Green 000 Snap
Blue 255 Snap
