I've just spent 5 hours at a venue programming some sequences, for upload to their Martin 2510. I've done this many times in the past no problem. My FS version is 3.5.7.
When I drag my sequences into the 2510 creator, Freestyler crashes. It happens every time.
can't create 2510 file
- Just started using FS
- FreeStyler Version: 3.5.7
- djSupport
Re: can't create 2510 file
have you marked this as a potential bug on the bug reporter? https://www.freestylersupport.com/bugs
no, it says I need to register, and when I try, it wont let me.
- djSupport
Please explain why it won't
- remco_k
- FreeStyler Version: N/A
Since the current stable version is 3.6.49, and you are using an older 3.5.7, please first update to the newest stable. Then retry and see if your problem still exists. If it doesn't: great!
If it does: report it as a bug as soon as registering has worked out.
I can't register for the bug reports because when I type in my user name, it disappears and asks again, and again. I can't upgrade to the latest FS version because it says my Microsoft NET version is the wrong version.
I've since uninstalled all FS programmes and gone back to 3.01, this works ok.
- djSupport
Search Microsoft for the latest .net version
- FreeStyler Version: 4.01
you need dot net 3.5
