Old Version Request - Freestyler App Not Compatible (yet/anymore)
While MAtt still is working (hope) on the app, does anyone have version between 3.6.38 and 3.6.42 for making available? "Old Version (http://www.thedmxwiki.com/dmx_control_s ... _downloads) Section is too old...
- FreeStyler Version: 4.01
Re: Old Version Request - Freestyler App Not Compatible (yet/anymore)
Hi Partyman, thanks for the help. I tested out your version, windows 7-64bit enviroment... It is something strange. Installed OK and soon as its starts to load, it gives probably an error message, but is impossible to read because it closes before complete show, and quits. DO you have any other installation between the versions?
... Same behaviour in a second machine.
3.6.34 Apply also.
I think things may have changed a little with the latest versions because I get errors also when I try to go to the older versions. The only way I get them to work is with a clean install.
I did that....
The only thing that works is a copy and paste from a late instal. (3.6.34) ... Will grab a machine with mint installation windows and try again.
also make sure you have installed Microsoft .net 3.5 Framework. Freestyler depends on it
installed 3.5, same result. quite strange.... do you have any other compatible with freestyler remote installable available?
I do not, the only remote that currently works is the "KMX" that is for iphone. I have just reverted to using teamviewer and doing everything with remote desktop
