I need to know if there is the possibility of loading a scenario with a different format than .evs, there is some software to convert it to .evs
please!! thank you!
									conversion software
				santis93
 - FreeStyler Version: 3.6.49
- Mattotone
 - Android Dev (Moderator)
 - FreeStyler Version: BETA
Re: conversion software
I don't believe there is, iv also not had any success in importing .step or .stl files into the object viewer.
