Master intesity bug, Also affects previous versions - FIXED
All previous beta Bugs will be moved to here on release of a NEW Beta
Locked
Android Dev (Moderator)
FreeStyler Version: BETA
Post by Mattotone » August 21st, 2007, 12:07 pm
Hi.
There seems to be an error with the master intensity.
Setting the intensity of a fixture using the lamp dialog's, seems to
be ignorged by the master intensity.
For example if i set the intercity to 100%, then change the master
intercity to 50%, the fixture goes back to zero. set master intercity
to full, fixture still at 0%.
But if the master intensity is set to 50% and i the set the fixture to
100%, it reacts correctly and the fixture is a at 50%.
If you manually set the intensity of a fixture using the side bar
sliders, it works correctly.
However now adjusting the fixture intensity using the lamp dialog
still is disregarded by the master intensity as it reacts to the value
set by the side bar.
Matt
Always have your stuff when you need it with @Dropbox. 2GB account is free! http://db.tt/J4c5G8C
Deploy your next app in seconds. Get $100 in cloud credits from @DigitalOcean using my link: https://m.do.co/t/1dfa4b120c4c
cantyco
FreeStyler Version: 2.96h
Re: Master intesity bug, Also affects previous versions
Post by cantyco » August 31st, 2007, 1:04 am
this might of jsut been me but i had probblems with this, and whenever i tryed to change the master intesity i used to have problems, and also got subscript errors, but i finaly discovered it was because one of my fixtures wasent assigned to a dmx channel. once i removed that fixture i didnt have any more problems. but this is a slighty different problem though.
Post by Mattotone » August 31st, 2007, 10:35 am
This has been fixed after the initial release of2.96G, If you have downloaded 2.96G before august the 24th please re download as the bug has now been rectified.
Locked
Return to “Previous Beta Bugs”
