Fixture Selection
The basic fixture selection is just to click on a fixture and it is highlighted.
When the fixture is selected all control panels related to the fixture are enabled.
Additional the Fader / Slider panel in the right side of the FreeStyler window is enabled.
The fixture selection is made so a fixture stays selected when other fixture are additional selected.
To deselect click on the fixture or to deselect “all” click on the background.
An additional selection tool is available “Selection” icons.
The “De-selection” icon deselect all fixtures.
Here the following selection tool / filter are available.
Select All
As the name says select all fixtures.
Even fixtures
Select all fixtures with no. 2, 4, 6, …..
Note that it is not necessarily the same as the name on fixture.
Even same fixtures
This select the same type of fixture placed on even no. 2, 4, 6, ….
Select one of the wanted fixtures and then select “Even same fixtures”.
All fixtures of that type with an even no will then be selected.
Odd fixtures
Select all fixtures with no. 1, 3, 5, …..
Odd same fixtures
This select the same type of fixture placed on even no. 1, 3, 5, ….
Select one of the wanted fixtures and then select “Odd same fixtures”.
All fixtures of that type with an odd no will then be selected.
The selection filter bellow the gray separation line are user defined filters.
See:Create Group
fixtures/fixture_selection.txt · Last modified: 2011/07/30 15:10 by djSupport
