Hi, everyone!
Does someone have to sell the interface described above inexpensively?
Of course, it should be working fully functional and clean worked. Please do not offer the industrially manufactured FX-5.
My price range is EUR 30,00 to 40,00 incl. shipping to Germany.
Please send me an PM.
Best regards
Jens
Searching: Digital Enlightment Interface
- LightJens1
- FreeStyler Version: 4.1.0
- FreeStyler Version: 4.14
Re: Searching: Digital Enlightment Interface
According to the webpage you could make one yourself.
But in other case i'd just buy a different brand, it's just a DMX controller and those work basicly all the same.
- LightJens1
Hello SIGNe!
Thank you very much for the tip about building it yourself, but that's not exactly my strength and so it's better if someone with more skill did it.
With regard to another interface, I have already gained experience with the one from Eurolight, for example, and the one from Digital Enlightment is much more stable in operation.
I also have two technically identical systems in operation, so the DMX interface should also be the same.
I have an Entec Pro, that works good too but that is more expensive too.LightJens1 wrote: ↑August 18th, 2021, 11:43 pm Hello SIGNe!
I did find the how to build page :http://www.digital-enlightenment.de/usbdmx.htm
But i'm no technician either.
You could try and find somene local who might solder it for you.
I'd ask around in your local vilage/city Facebook group.
Then you only have to buy the parts afterwards (saves mail costs too)
- LightJens1
Hi SIGNe,
I know the site and indirectly I had this part built for me at that time.
As for the production: I'm a technician, but the part also has to be programmed and that's exactly where I'm out.
The users of DMX-Control work a lot with the DE interface. So I'll probably find my way over the Board of them ...
