Add the option to add transitions to buttons.
- FreeStyler Version: 3.6.3
FreeStyler is a very powerful program however one of the features that I believe should be added is the ability to add a fade transition when you pick another button. So that the program moves smoothly between the two colors and is not an instant jump. This would be a very good addition to the program in my option.
- FreeStyler Version: None
Re: Add the option to add transitions to buttons.
This can be effected by the fixture itself as well, which is a problem. If you have old moving heads with colour wheels, it uses a stepper motor so fading can be difficult. But CMY or RGB colour mixing, yeah go for it.
