RGB Pixel chase
Rosspunk
FreeStyler Version: 3.5.7
Twitter: https://twitter.com/DropTheBiscuit
RGB Pixel chase
Post by Rosspunk »
Anyone got a suggestion for a single colour snap chase for 64 LED RGB pixels? I want to do a chase of one at a time and play it at the same time as a separate submaster for just single colour for all LED's (so it looks like the LED's are twinkling.
buttza
FreeStyler Version: 3.6.4
Twitter: twitter.com/@buttza
Re: RGB Pixel chase
Post by buttza »
Are you talking about if your current lighting colour is red and you run a random white flash over the top of your existing cue to random LED par 64?
Rosspunk
Re: RGB Pixel chase
Post by Rosspunk »
Yes. If all the pars were red and run a white chase over the top so when a par has flashed to white it reverts back to red.
Rosspunk
Re: RGB Pixel chase
Post by Rosspunk »
I suppose i should fess up. I used to be a lighting designer for about 20 years with extensive knowledge of Avo lights desks (Pearl to Diamond) and Whole Hog. Worked for a number of well known bands, but doing this as a hobby for the occasional small local party. I am going to run this from Akai APC mini eventually.
Return to “Ideas and Remarks”
