Fogger fix
heythereitsme
Fogger fix
Post by heythereitsme »
Just a note to anyone that might be searching for a problem with a fogger immediately automatically fogging when Freestyler is loaded and you plug the DMX in...
It turned out the simple fix was to just select a different DMX interface in Freestyler settings, ok it, then returning it back to my actual one, it stopped the auto-fogging and it all works fine now!
Return to “Ideas and Remarks”
