Blackout With Freeze
Memory
Just started using FS
FreeStyler Version: 3.51
Post by Memory »
Hi, when I press Blackout, the sequences are always running... by blackout, all must stop (freeze)!!!...
Best regards
Re: Blackout With Freeze
hi
by default on all lighting software/desk the blackout will only black out and keep on running the sequence.
as there is also a feature "Ignore blackout" so in that case you dont want to freeze everything.
Memory
Post by Memory »
I know that... :-) , but when all softwares are doing that FS must do that :-)!!!?
it will be possible to do edit in the option Blackout "with" or "Without" freeze...
ignore blackout/fiscture it's not the same :-)
THANK YOU
oke i see your point.
there's a button (link) on top of this page "submit a bug report" here you can also add Feature request and let the devolper decide about it. good luck.
and for now you can do this with midi and you pc keyboard.
get Midibomes assign a keyboard stroke and send 2 midi notes to the blackout/freeze functions.
also get midiyoke to create a virtual midi connection between midibomes and freestyler.
Return to “Ideas and Remarks”
