FS resets Keyboard shortcuts
Mikro
FreeStyler Version: 3.5.4
I Use FreeStyler for: Theater
Post by Mikro »
I am desperately trying to set up a standard preset I will normally use to program FS shows. Because I use my smal NanoKontrol2 for operating live shows I mapped some of my shortcuts to Keyboard. But there´s the problem. FS resets all my shortcuts every time i close it down, so I have to map a lot of keys over and over again.
I solved this by exporting the preset for MIDI and have to load it every time again. Its not the worst thing to do. But what about keyboard shortcuts? How to save them? Please help.
jdmyers
Re: FS resets Keyboard shortcuts
Post by jdmyers »
Hit Save after setting your keyboard shortcuts on the Settings menu, then Go to File -> Save Location to make sure everything comes back up as you have it... this only works with MIDI devices if you have them powered up before starting Freestyler, but should always work with the keyboard shortcuts.
