Velleman or other Dongles
Which Velleman or other brand do I need? This has probably been posted on here but I'm new to these forums. Thanks
- Spirit
- FreeStyler Version: 3.5.9
Re: Velleman or other Dongles
hi..
velleman isnt my first choice i have used it before but its not the best DMX dongle out there..
The most commen used DMX dongle is the Enttec pro..
Nower days the DMXking Pro is a very good choice as i works on the Same driver as the enttec pro...
only DMXking seems to have a realy good Support service..
and keep in mind your DMX dongle is the Base of you Lighting equipment so get a Good one!!!
there are many other Realy!!! cheap dmx dongles that are not stable and will crash durring the Lighting show..
