I have created fixture files in M3DEV and Fresstyler for the following fixtures.
Martin:
MAC 250 Krypton in Extended mode 17 Channels
Eternal Lighting:
Premier 120 Watt LED Moving head. 16 Channel Extended
Showtec:
Tri Color Par 64 LED 6 Channel Mode
I have tested these and they are accurate.
Any questions then please let me know.
Please note that the Gobos might be slightly different as there are 2 version of Gobo sequences / order for MAC 250 Kryptons.
Fixture Updates for Martin and Eternal Lighting Fixtures
- buttza
- FreeStyler Version: 3.6.4
- FreeStyler Version: None
Re: Fixture Updates for Martin and Eternal Lighting Fixtures
Thanks for submitting these, buttza
I keep meaning to do a few myself for FS and 3D view, but with being so busy with work I never get chance Keep up the good work
- buttza
All good. I know how time consuming they can be especially getting them working the correct way. I like the visualiser. I do alot of my work throught it now. Wish I could afford the full version tho. One day. Hopefully they can get the media servers running through them.Nathanrs93 wrote:Thanks for submitting these, buttza
Sample of the last one I created.
Hey,
Is that with 3D easy view? What you mean buy the full version?
Pictures are really good Any chance of a video or two?
- buttza
That is with M3DEV . The video capture doesn't work withit unfortunately. Need the full version to capture video. I will try and use some other capture software to show working version.
Oh right, well I know 3D easy view just needs an interface to go into full mode. But if you get it working like I say it would be interesting to see it in actionbuttza wrote:That is with M3DEV . The video capture doesn't work withit unfortunately. Need the full version to capture video. I will try and use some other capture software to show working version.
