edirol(roland) pcr300
gazp
FreeStyler Version: 3.5
Post by gazp »
Hello, got some trouble whit the note keys, all knobs faders buttons work when i assing them to freestyler midi controls, but the note keys wount work, they only can be assinged to control functions what are blue colored, i see that freestyler recives midi note when i press key, For example, i assign 1 note key to owride button 1 then i can see values there but afer saving seting it just wount trigger oweride button 1, i tryed edit note keys by edirol pcr editor but it wount give me any result,
Kings
Commited FS Forum helper
Re: edirol(roland) pcr300
Post by Kings »
You need to set the keys to always produce the maximum value of 127 (just like if you we're to push the key down very hard). FS will only respond to the maximum value.
you can also change the MAX Velocity on the Freestyler.ini if its realy hard to change that on the midicontroller.
