BCF 2000 MIDI pages
YOU MUST FILE A BUG REPORT HERE before discussing possible bugs.
PePu
BCF 2000 MIDI pages
Software Version 3.3.2
Controller BCF 2000
Hello, I have a problem with setting the BCF 2000 and midi pages.
I set the controller to the 4 buttons to toggle MIDI pages.
In a MIDI I programmed the 1-8 sliders to control PAR 56 DMX 1 to 8 The MIDI 2 I programmed the 1-5 sliders to control submasters 1 to 5
If in a MIDI light a PAR 56 with the pull switch potentiometer 1 and 2 in the MIDI control the way any PAR potentiometer 56 in parallel with submasters ....
Can you help?
Controller BCF 2000
Can you help?
- remco_k
- FreeStyler Version: N/A
Re: BCF 2000 MIDI pages
Please post a question once on this forum. Crossposting the same question in another topic is not a good idea.
I've read your question 4 times now. I can't figure out what youre problem is. Try to explain better.Can you help?
PePu
I apologize in advance for the English (Google Translate) and insert the paper into multiple threads ....
I will try to describe my problem more ...
Controller BCF 2000
The first button switch MIDI pages I programmed so that the sliders 1-8 DMX channels directly control 1 to 8
Second button switch MIDI pages I programmed so that the sliders control submastrs 1-5
When I switched to a MIDI DMX speak the values 1-8 that's fine, but when I switched to MIDI 2 to control the value of submasters 1-5,and at the same time as DMX values 1-8
Controller BCF 2000
PePu
i can't see anything "wrong" in the fms file..
let me see if I understand you correctly. when you have pushed the "MIDI page 2" a fader control both the submaster AND DMX output? its not because you have have sequences in the submaster which sends out dmx to same channel?
PePu
Yes, I switched to MIDI 2 and moving the potentiometer to change the value of DMX channels to submasters
I'm sorry, but i'm still not sorry i completely understand you and what the problem is.. is it a problem or are you asking what to do something? if you think it is a problem please answer:
What did you do?
What happened?
What did you expect?
What did you do?
What happened?
PePu
I have set:
1 button switch MIDI pages I programmed so that the sliders 1-8 DMX channels directly control 1 to 8
2 button switch MIDI pages I programmed so that the sliders control submastrs 1 to 5
We expect:
If you switch to a MIDI 1 controlled only the value of DMX 1-8
If you switch to MIDI 2 to control the value Only authorized submasters 1-5
How it works:
If you switch to MIDI 2 to control the value of CURRENT submasters 1-5, and changing the value of DMX channels 1 to 8 (Change in value submasters also controls the DMX values 1-8) This is wrong.
We expect:
How it works:
I have tried to reproduce the issue, but i can't. I have double checked your fms file but can't see any problem...
I have to ask you again: do you have any sequences in the submaster which control one or more of channel 1-8? to be sure you should do the test without any sequences in the submaster
PePu
Submasters controls a sequence of RGB RARS - DMX 20,25,30 .... . I do not have a single sequence that includes DMX 1-8. That's just weird ...
have you tried to reassign the midi? maybe that will do the trick
which midicontroller are you using?
Re: Re: BCF 2000 MIDI pages
Sorry, you wrote that in your first postPePu wrote:I use the BCF in 2000 connected to a PC via USB
I think you should make a bug report if no one else have a solution
Sent from my HTC Hero using Tapatalk
PePu
You work properly?
This weekend a film videos as I graduated from freestyler setup, configuration BCF 2000 and connect dimmer LED PAR ......
- remco_k
Really, you should do something about that English language. I mostly have no clue what you are saying. So I can't help out. LJ_Krede is trying but struggling with the language too. I'm from the Netherlands, LJ_Krede from Denmark, people from England are reading along also, I guess no one understands a thing.PePu wrote:You work properly?
- djSupport
He's from the Czech republic maybe google translate?
whale-av
Hey, what crazy you say is it.
I seem to remember reading somewhere that the submaster faders control channels 1-20 until they are "used" - that is - until a cue has been loaded and run. Could that be PePu's problem. If he loads a cue full of fixtures that have no intensity channel (there are some in the FreeStyler included fixture files) then I assume that it would not be "used" and the sub faders would continue to control the channels 1-20. Pepu might also have made his own fixtures and not entered an intensity channel. Or my talk bottom out of.
