IMG Stageline DMX-510USB
.rrr.
FreeStyler Version: 3.4.8
I Use FreeStyler for: Church
Post by .rrr. »
Hi guys,
I finally got my new IMG Stageline DMX-510USB Box. Looks nice, but it didnt work.
My specs: Win Vista 32bit, for Testing: 1 LED PAR 56 on DMX Ch 1
I installed everything with this guide on the cd. The thing is: it seems to work with the included software "dmx510usb" - but in Freestyler I cant found anything if my interface is connected and if it works.
I started with freestyler with a little guide. So Ive choosen my Interface in the Pref Panel. But the LED PAR stays off.
I have no idea - can someone of you pro guys help me out?
Thanks, .rrr.
:fs:
Kai-Uwe
DJ
FreeStyler Version: 3.2.1
Post by Kai-Uwe »
Right Comport? Cables connectet before FS starts? What did the output say?
Sent from my iPhone using Tapatalk
Vista - Virus Inside Switch To Apple
.rrr.
Re: IMG Stageline DMX-510USB
Post by .rrr. »
Hi Kai-Uwe,
danke für deine Antwort - ich nutze USB. Aber ich hab glaub ich gemerkt, woran es lag:
Man muss wohl Freestyler als Benutzer mit Administrativen Rechten starten.
Aktuell scheint der Test mit 2 LED PAR Kannen zu funktionieren.
Das einzige was mich wundert ist, dass per Blackout Button nur einer der Beiden LEDs aus geht.
Hast du eine Idee?
Mavi
LJ
FreeStyler Version: 3.2.8
Post by Mavi »
@.rrr. pleas keep typing english so everyone can read everything (and try to help)
.rrr. wrote:Hi Kai-Uwe,
Hast du eine Idee?
English translation of the above:
Hi Kai-Uwe
Thank you for your answere - I am using USB. But I think I found out what the problem was:
You have to start Freestyler with administrator rights.
Currently the test with 2 LED Par Cans seams to work.
The only thing suprising me, if I hit blackout only one of the two LEDs shutes down.
Do you have any idea?
M4rky
FreeStyler Version: 3.5.1
Post by M4rky »
I have the same dongle & mine is not playing ball with me!
How would you get admin rights on windows?? (sorry!)
I did the install ok, the driver loaded, but mine just isnt working!
I tried the unit on a win 7 netbook & also a win xp netbook (Lucky to have 2 netbooks!!), but still no joy....
The unit lights up to say it knows the netbook has a driver & is attached, but no output from the unit to my abstract VR8's....... GUTTED! :x :x
Any help would be gratefully received! :D
Thanks peeps
matt
Admin
FreeStyler Version: NULL
Twitter: twitter.com/hankosky
Post by matt »
In windows 7 / Vista, Right Click the FreeStyler icon and select "Run as Administrator"
Matt Hankosky
flickr.com/photos/mattxhank
funkyds
Post by funkyds »
hi,
i have this dmx usb box, but the cd is damaged does anyone have a copy they can upload and send to me so i can get this working.
many thanks in advance.
Return to “DMX Interfaces”
