I've been following a couple of threads and have just had a thought...
Can we get a 'super blackout' button. A button that sends out zero's across all channels regardless of what function FS thinks they provide.
Why?
I use FreeStyler in quite a largeish church set-up with LED washs and DMX dimers. A lot of the fixtures are inaccessible, and hence we cant shut them off (standard practice in theatre situations I think).
It would be good to be able to shut everything off at the end of the day with a super blackout. (blackout sometimes wont shut off the LED's so I have had to make a cue list item called Blackout that does it manually for me, that or just restart FS)
Or am I missing a feature that currently exists?
Cheers
Reg
SuperBlackout Button
- FreeStyler Version: 3.2.8
- Twitter: twitter.com/regorton
- dmxlighting
- FreeStyler Version: beta
Re: SuperBlackout Button
I think it will work with the intensity channel and maybe the lamp channel too ? Could be wrong ?Onge wrote:As far as I am aware, to ensure that fixtures blackout you have to use the shutter channel.
- stuv
Why not use a favorite of every channel set to zero? I do this regularly as i also run into the problem of no true global blackout.
As a side note, a useful glitch in freestyler (note: useful = please don't remove) is that if you are in favorite mode, and you then activate and de-activate blackout you then have control over the shutter channels of all fixtures while all other channels stay in blackout. I used to use this regularly to favorite on the mirror ball with the movers, then gain control over the shutter channels and start them strobing on the buildup before leaving favorite at the peak and going back into movement.
- FreeStyler Version: 3.5.7
- I Use FreeStyler for: Film
Hello,
Do you think it could be possible to create a "Set as blackout value" option in the Edit Menu of Freestyler.
Something that records all the channels values when you click on the option and set them when blackout button is pressed. And the best of the best would be the channels values to be saved when Blackout is pressed to be restored when Blackout is toggled off.
Thanks by advance for your interest.
PS: Sorry for my English...
- FreeStyler Version: None
The problem with LED fixture if used in RGB and nothing else then technically they have no dimmer or intensity control. It is also in LTP has it's colours being controlled, the way around this would be a virtual dimmer which in theory is like a dummy dimmer which blackouts it out. I'm not sure how to do it on FS as I don't use the software any more, but it's what I do when I'm using RGB fixtures.
- FreeStyler Version: Beta
Hej
There is a feature request on having a macro which can be used as black out.
It will this way be possible to make a blackout where the user define what channels to set in "Blackout"
http://www.freestylersupport.com/bugs/view.php?id=900
