Like someone said in the forum
http://www.freestylersupport.com/fsforu ... ?f=6&t=178
It would be very interesting to have a timeline window where we could put sequences , just like adobe premiere or any video creator. That would compensate for the few 20 cues we have in the cues window.
And with a tap tempo sync to follow the beat of the music (because a music band doesn't always play at the same speed each time).
(if you need help programming all this, I can help you, just ask)
timeline
- djSupport
Re: timeline
i can say tho this would be a powerfull feature.......
Re: timeline
I would actually also be very interested in te "timeline" option. I would be very easy to make a changing show by just draging the cue and maybe submaster sequences over in the timeline window.
- Mattotone
- Android Dev (Moderator)
- FreeStyler Version: BETA
Re: timeline
Its been asked alot before on the old forum, i think it would be quite difficult to implement in the current version because of the way scenes are currently run.
Maybe reserve for a freestyler 2? who knows.
Matt
Matt
Re: timeline
Is the Timeline function used in other light control software like ex. lightjockey, because i newer seen it in any light control software?
- Mattotone
Re: timeline
A fair few software are using it now, Easyshow is just one, but im sure you will find it hard to get one in free software, its quite a lot of work.
- Just started using FS
- FreeStyler Version: 2.96f
Re: timeline
I think it could be implemented the same way as the cue list,
on the timeline, we put the cues that we want, and when we press a play button, a line goes from left to right, when the line come on a new cue, then a command is processed to start the cue , just like the cue list
am I wrong?
am I wrong?
Re: timeline
In the meantime, is it possible to have the possibility to launch cues directly from the browser window? I would save some click and we could see all the cues we want with the folders and start cues on the fly
- Mattotone
Re: timeline
load your folders into the submasters, and run them from there.
