In the "DMX Terminator How to" I found this link
http://www.emanator.demon.co.uk/bigclive/dmxtest.htm
Is it right that the tester (with two LEDs(right picture)) works also as Terminator?
DMX Terminator
- FreeStyler Version: 2.96h
- FreeStyler Version: 3.01
- Twitter: http://twitter.com/jaykie
Re: DMX Terminator
I guess the one with LED lights indeed is a teminator too after I've read this sentence.If the tester is not going to be used as a terminator, then the shunt resistor across pins 2+3 can be omitted, making the unit simpler to construct and allowing the network voltage to float a little higher.
- Admin
- FreeStyler Version: NULL
Re: DMX Terminator
Matt Hankosky
flickr.com/photos/mattxhank
