Enttec USB DMX PRO Mk 2 Topic is solved
djnyce
Re: Enttec USB DMX PRO Mk 2
Post by djnyce »
i just ordered this. any luck getting it to work? i have show new years and if it doesn't work with freestyle, i'll have to send it back and get the old enttec.
M4rky
Post by M4rky »
Nothing yet, but still trying! I would stick with the pro mk 2 if I were you, its a better build & more options (when we can get it to work!!). Will do a full reset later & if needed, a delete & reinstall. Let you guys know how i'm getting on.
djnyce
Post by djnyce »
any update on this?
one little update.
i noticed on the new Beta that the Enttec pro MKII is added to the list of Interfaces.
djnyce
Post by djnyce »
still doesn't work with the latest version 3.5.2, the mk2 is available as a choice. but as soon as you click save, an error pops up saying Open Failed.
hi
please submit a BuG report about this.
http://www.freestylersupport.com/bugs/main_page.php
so the devolper can try to fix it..
/Spirit
djnyce
Post by djnyce »
djnyce wrote:still doesn't work with the latest version 3.5.2, the mk2 is available as a choice. but as soon as you click save, an error pops up saying Open Failed.
issue has been resolved. running freestyler in admin mode fixes the problem.
so far the mk2 is working like a breeze with 3.5.2!
MIDIDMX
Post by MIDIDMX »
Hi All,
did anybody tried to use the MIDI feature of ENTTEC DMX USB PRO MK2 with Freestyler ?
I so, please provide describe your experience.
I did try and I could get it work !
Probably Freestyler has not implemented yet the MIDI side of the hardware or else.
Also according to my experience the ENTTEC DMX USB PRO MK2 doesn't seems to me to have a standard midi implementation as my Midi softwares cannot detect the midi ports of it.
Please let me know.
Thank you.
MIDIDMX
Post by MIDIDMX »
I just need to correct my previous posting :
Please change "I did try and I could get it work !" with "I did try and I could NOT get it work !"
Sorry.
rosesound
Just started using FS
FreeStyler Version: 3.632
I Use FreeStyler for: Band
Post by rosesound »
Hi
I also just got the ENTTEC PRO Mk2.. damm with that MIDI .. I hoped to midi control Freestyler with it, so no need for an extra MIDI interface... DO NOT BY THIS DEVICE (for MIDI)
rosesound
Post by rosesound »
It lookes like that Enttec push it over to Freestyler, see my mail from support...
Jens
MIDI Support, just like DMX is software supported only
I would contact Freestyler to see if they plan to support MIDI on PRO MK2
It doesn't need any special drivers, just has to be supported by the software or App
Manmeet
Sales & Support
ENTTEC AU
On Sun, 09 Feb 2014, Jens Kristian ?stergaard wrote:
-show quote-
Reply
To: support@enttec.com
Date: Sun, 09 Feb 2014 20:57:08 +1100
IP: 188.176.254.70
Hi
I just purcased this unit with midi cable. I want to use it with Freestyler and the dmx seems to work fine, but the MIDI...????
Windows cannot find the midi device and Freestyler can not either.. and this is bad because i send notes to control cues in FS
How can you fix this.. are there an FW fix or some software... or shall i return the unit..
Regards
rosesound
Post by rosesound »
rosesound wrote:It lookes like that Enttec push it over to Freestyler, see my mail from support...
Jens
Manmeet
Sales & Support
ENTTEC AU
-show quote-
Reply
IP: 188.176.254.70
Hi
Regards
rosesound
Post by rosesound »
So will Freestyler support this MIDI in Enttec Pro Mk2..?
Post by Jan_K »
Have you placed this in bug tracker as a feature request.
rosesound
Post by rosesound »
Yes I did make an request in the bug tracker, but I will return the Enttec, I can not wait until FS will support this.. shure they do some time... and I will not pay so much for an DMX interface with the MIDI support not working.. /JK
hi you can try one other thing.
as enttec say it doesnt need a Special driver to let it work...
so to me it sound like it allready should work, if its a normal midi interface..
but donwload MIDIOX and take a look if this software supports the Midi port from the Enttec pro MKII
djkoak
Post by djkoak »
I have even downloaded the enttec software and most current drivers and firmware, the enttec software recognizes the midi but freestyler does not recognize it on the input or output side
Return to “DMX Interfaces”
