First have you tried? Log in to Search the Forum for help! Learn more about using FreeStyler at the FreeStyler WIKI HERE
So iv been through the tutorials, created my fixture. All working except for the colours, the only colour that works is red. The others are different and when i click on another colour in freestyle it also makes my moving head move continuously. Any help on this would be awesome. Iv attached my fixture file and manual for your information
You have placed the color wheel on channel 7.
It has to be channel 6.
Also remove channel 6 from lamp the channel.
FreeStyler uses the dimmer channel to make lamp on off is the shutter channel isn't defined. Lamp channel is for striking the bulb
Strobe channel set the "Off" value to 0 and low to 5 or 10 and delete the med value (It should be calculated automatically)
If you want to use sound control then I will suggest that you add two macros a "Sound off" and a "Sound off" and then only add the value 0 and 255 on channel 7 for the macro.
okay.
I think you should try to debug the fixture.
You have 7 sliders in the right side of FreeStyler
If you move them one by one then you can see what they do.
Verify that channel 5 is the strobe control and check in Fixture Creator that you only have defined / used channel 5 on the strobe.
It may also be an idea to upload the fixture here then I have a chance to look into it.
color1 at the top doesnt do anything
pan works fine
tilt works fine
color2 doesnt do anything
dimmer works fine
strobe works fine
color1 at the bottom changes the color,
Strange though because the channels do not match those in the manual.
Manaul My Settings
Strobe 5 Strobe 6
Pan 1 Pan 2
Dimmer 4 Dimmer 5
Im still working on the color
