Hello Freestylers,
I am looking to get a file for the Equinox Scantastic 4 but the e-mail I sent to get this created was bounced back by the server.
My biggest hurdles are that:
1) I am new to Freestyler and DMX so don't now the top of my leg's from the middle of my arms
2) There are 4 scanners on the device but only 3 gobo option things,,,,
The manual is avaliable at:
http://earlyriser.co.uk/applications/as ... Manual.pdf
Any help would be very much appreciated. Thanks. Monty
Scantastic 4
- FreeStyler Version: 3.5
Re: Scantastic 4 - Solved
They say neccesity is the mother of invention, well, they be right.
I managed to create the file, well, files, and will upload them.
I had to make 4 separate files, each with different pan and tilt addresses and then you combine them in Freestyler to control them all.
I cant promise it will give 100% control of the machine but I would say you have 80%.
- FreeStyler Version: Beta
Re: Scantastic 4
Sorry for not guiding you.
There are some tutorials on the wiki. (If you have not already been there)
http://www.freestylersupport.com/wiki/f ... ter_effect
