STAIRVILLE MH-X25
Locked
PSR-1500
STAIRVILLE MH-X25
Post by PSR-1500 »
Hello
I bought myself a moving head STAIRVILLE MH-X25.
I would like to control the STAIRVILLE MH-X25 with freestylers.
The function diagram of the DMX channels I have.
What color in which DMX value, etc.
Can someone help me with creating of the moving head for freestylers?
It is very important, but I can not program the fixture Creator.
Thank you!
Deutsch:
Hallo
Ich habe mir einen Movinghead STAIRVILLE MH-X25 gekauft.
Ich möchte den STAIRVILLE MH-X25 mit Freestyler steuern.
Den Funktionsplan der DMX Kanäle habe ich.
Welche Farbe bei welchem DMX Wert etc.
Kann mir jemand beim erstellen von dem Movinghead für Freestyler helfen?
Es ist sehr wichtig, aber ich kann den Fixture Creator nicht programmieren.
Vielen Dank !!!
stefanf
Re: STAIRVILLE MH-X25
Post by stefanf »
If you provide me with the dmx list I'll make you a fixture file, if you still need it.
dmxlighting
FreeStyler Version: beta
Post by dmxlighting »
PSR-1500 wrote:I can not program the fixture Creator.
Yes you can! There are tutorials on this forum and on the wiki.
Making fixtures for FS is SO EASY! Most fixtures can be maked in about 5 to 10 minutes.
If you can program FS to control your lights then you can use the fixture creator. No such thing as 'I can not...'
Anyway here is a chart showing all the DMX commands for this fixture
Onge
Post by Onge »
In a happy mood so have started this for you.
Not tested as I do not have the fixture.
See this post for more info and the fixture file.
DJ Kris
Post by DJ Kris »
I'm working on this feature file at the moment.
Please find beta tested Freestyler Feature file on this location: http://www.no-external-links-to-fixture ... llowed.com
V1.0 has these changes:
A) mechanical dimmer is open per default
B) Increased the number of colors, half color combinations and rainbow effects to 48 in total. Created BMP files that match the colours of the Stairville MH-X25.
More to come in the next days.
Reason: Removed external link to fixture file
FreeStyler Version: N/A
Post by remco_k »
Lets continue in this topic.
Locked
