Better Touchscreen support => Draw you virtual Interface Topic is solved
jayjay89
Post by jayjay89 »
this is a very cool feature i found in e:cue and other programs. You just draw your buttons, faders and whatever and assign functions to them. It would be cool to have this ability in freestyler too.
Examples:
http://www.daslight.com/IHM/picts_news/ ... eb_579.png
http://www.ledstyles.de/index.php?page= ... embedded=1
Re: Better Touchscreen support => Draw you virtual Interface
hi with fs you have 2 differnt touchscreen interfaces.
one pre-made, and one you can create your own touchscreen interface.
http://www.freestylersupport.com/wiki/e ... screen_ui1
http://www.freestylersupport.com/wiki/e ... screen_ui2
as example i made one for a good friend of mine you owns a Paintball centrum.
with Cuelist control and some Override buttons..
https://www.dropbox.com/s/0p6vei95bx04x ... ll%201.png
https://www.dropbox.com/s/gsbbq32v27828 ... ll%202.png
and here a Example i use and still busy on.
One for my Laptop with touchscreen and a Other with all 180 Override buttons on a 22"touchscreen :shock:
and both with the Submasters list on it..
https://www.dropbox.com/s/351dybtbtabhu ... %20TUI.png
https://www.dropbox.com/s/7lt89pc8o42bbbn/Test1.png
Return to “Ideas and Remarks”
