RULES: Feature Request
- LJ_krede.dk
- FreeStyler Version: 3.3.7
Hi All.
To make a better overview for FS users and the FS developer Raph, all Feature
requests/suggestions have to be reported to the http://www.freestylersupport.com/bugs
1) When you are logged in to the FsBT click on "Report Issue/Feature Request"
2) Choose the Project "Feature requests......."
You can also discuss reported requests in FsBT
you can still use the old Ideas and Remarks topic to discuss ideas before requesting them in the FsBT.
http://www.freestylersupport.com/fsforu ... um.php?f=7
!!Remark: FsBT can not retrieve usernames and passwords from this FS forum so you have to make a new account for this.
Have fun!
Have fun!
federicomonzon
- FreeStyler Version: 3.5.4
- I Use FreeStyler for: None of your damn business!
Re: RULES: Feature Request
hola: tendrias un listado de los controladores midi que se puede controlar freestylers?
muchas gracias saludos
redvandan
I signed up but for some reason I cant find the feature request any place I look on this site I see every thing else to report a bug.
- djSupport
Fill out a report and in the severity option choose feature request.
- djSupport
I have replied to your email.
- djSupport
You have also posted in the wrong place.
Keibir
Bugtracker registration doesnt work. I do not get an Email. (Not in Spam or junk also)
I tried 2 different mail-adresses and waited several days.
DavidT1971
- Just started using FS
- FreeStyler Version: x2 4.1.1
I too cannot get the bug tracker to send out any confirmation emails for registration. have been trying for a couple of weeks now to request the touchscreen functions be looked at to support multi touch etc
- djSupport
David, I see you've registered multiple times with different email addresses have you checked your spam inbox on your emails?
- djSupport
I can only think your server is blocking or 'spamming' emails from the bug tracker, the forum uses outlook to send emails but I can't do that with the bug tracker, I'm currently at work driving buses and I'll check in with you later
DavidT1971
I have checked all spam and junk mail folders -- nothing has arrived. Thanks
- djSupport
I got back from work late, I had a brief look but can't remember how I enabled someone before, do you not have a mainstream email account? I sent a reset password to freestyler@ email address check to see if you have itDavidT1971 wrote: 07 Dec 2022, 13:54 I too cannot get the bug tracker to send out any confirmation emails for registration. have been trying for a couple of weeks now to request the touchscreen functions be looked at to support multi touch etc
- djSupport
I sent a resset to freestyler@dthomson.co.uk but the software is already saying your active? let me know how you get on...
DavidT1971
Thanks mate -- I didnt get any reset through etc. I will try forgotten password for the bug tracker with that login and see if it comes through ok, I have catchall on certain domain names, and use the first section before @ to identify where emails are coming from etc. That way if I get spam from certain ones I can immediately block them etc.I dont have any block on the freestyler one. im off out to a gig just now, so will check when I get back
Thanks for all your help so far, really appreciated
Dave
Dave
- djSupport
Your server is rejecting our emails due to a rdns issue it only effects some people, I need to figure out how to correct it, the forum is setup differently so isn't affected, I tried to setup the same but mantis bug tracker system is not compatible
