Robe Colorspot 575 AT MODE3
so here the Robe Colorspot 575 AT Mode 3
tested with a real Robe Colorspot 575 AT Mode 3 and the PDF
Works also with Magic 3D
V1.0
-added Color 1&2 Proportional
-added Color 1&2 Step
-added Color 1&2 Color chase
-added Gobo 1 Continual Positioning
-added Gobo 1 step
-added Gobo 1 Shaking
-added gobo 2 index
-added gobo 2 Rotation
-added gobo 2 Shaking
-added gobo 2 Shaking and rotation
-added Factory default gobo pic's
V1.1 - V3.4.4 and higher
-added Global Id
ColorSpot 575 AT V1.1.pff
(237.6 KiB) Downloaded 85 times
ColorSpot 575 AT Mode 3 V1.0.pff
(237.52 KiB) Downloaded 100 times
ColorSpot 575.pff
(120.52 KiB) Downloaded 112 times
stuntedmonkey
Re: Robe Colorspot 575 AT MODE3
Post by stuntedmonkey »
This is just what I needed! Thank you! Are you able to also make one for Robe ColorWash 575 AT Mode 3?
stuntedmonkey wrote:This is just what I needed! Thank you! Are you able to also make one for Robe ColorWash 575 AT Mode 3?
yes i will look in it for you :D
kings01
Post by kings01 »
Hi guys, I know this is real old thread but I need help. I cant get solid color using this fixture in Magic3D. Can you help?
tracky
Post by tracky »
Throwing up an old thread without an answer, does anyone know why I can't get a Solid Color using the Colorspot 575 AT Mode3 with Magic3D ?
Thank you in advance,
Julien.
Hi it tried it.
But on the New 3d view version 2012.5.21.3054
Nothing on any fixture doesnt work anymore.
so if you like to have the fixture working on 3d view you need to Recreate the fixture from cratch again.
i allready recreated some of the fixture but not everthing at the moment.
tracky
Post by tracky »
Thanks for your quick answer.
Perhaps it is worth it trying with an older version of 3d view... I'll check.
See U !
Julien.
You can only use the 3d view your Installing the same time as freestyler.
Return to “Robe”
