Slim Par tri 7 IRC
Nathanrs93
FreeStyler Version: None
Slim Par tri 7 IRC
Post by Nathanrs93 »
Here is the fixture
UNTESTED
7 Channel Mode
I've used
IRIS channel = Speed control
Focus channel = Pulse effect
Frost channel = Auto fade/snap transitions
2nd Frost channel = Sound Active Mode
SlimPAR Tri 7 IRC.pff
(9.49 KiB) Downloaded 81 times
billybob132
Re: Slim Par tri 7 IRC
Post by billybob132 »
Thanks that's great. I tried using the par56 file and it worked but was a little flaky!
Thanks again!
Nathanrs93
Glad to help 8-)
newbie84
FreeStyler Version: 3.2.1
Post by newbie84 »
Does anybody know if this fixture will also work for the Chauvet SlimPAR Tri 12 IRC? It's the same light as far as I know but there's 12 LEDs rather than 7.
http://www.chauvetlighting.co.uk/slimpa ... 2-irc.html
CaptainBetty
Post by CaptainBetty »
If the channels line up... shouldn't be an issue.
Return to “Chauvet”
